Evening guys, DIYer here. Just planning out new kitchen and have a question for you. Just wondering if you can wire a cooker hood and gas hob (iginition only) to the same switch? Also, would these be wired directly to the switch? Thanks in advance.
What switch are you referring to? A light switch? Dont forget requirements for electrical work in kitchens, Part Pee, John Shagscott etc etc etc/ Bazza
Aahh, much clearer when you say what you mean. Yes, Put the correct fuse in it (no more than 5A) and you could run both from the one Fused Connection Unit (=FCU) Bazza
who is notifying this job for you? or have you already notified LABC and paid the fee? I assume the you naturally want the job done correctly?
