Hi All I need to convert a 240v petrol generator supply into two 12v / 70a feeds and one 24v / 85a feed...or possibly the other way around. Load would not be continuous, just need to run 3 motors intermittently for 3 or 4 seconds at a time. Had a quick look on the maplins website at their transformers but can't see anything that can supply the amps at that level. Can someone point me in the right direction or let me know if you need more info? Thanks in anticipation G
Just to clarify, am trying to replace the feed from lesiure batteries on clay pigeon traps, getting fed up with hauling them about and re-charging them.
12/24 volts at those currents is goint to be a tall order, is the generator up to it? You will need some pretty big transformers, far bigger than anything sold by Maplins I think.
Just to clarify, am trying to replace the feed from lesiure batteries on clay pigeon traps, getting fed up with hauling them about and re-charging them. In that case I very much doubt that you will need that ammount of power. Are you getting your amps from what is written on the batteries?
Correct Oliver, I know that we struggle with the 60Ah batteries and need to use 70 and 85Ah...forgive my ignorance, now I think about it Amp hour and amps are 2 different things...guess I would need to check the plates on the motors?
In very easy laymans terms the amp-hour is how much electricity is stored. You will probably find the rating of the motor is very low.
Yes the AH is what the battery is capable of delivering, in simple terms an 85 AH battery is able to supply a load of 85 amps for a period of one hour. You really need to check the demand of the motors, I would suspect it's fairly high. I am guessing the motors will be similar to car wiper motors with built in gear boxes.
Thanks S&S, so I guess check the motors before we proceed? Or are they likely to be 'standard' ? I haven't a clue to the ratings of that type of motor, but i am sure handyandy will give another compleatly uneducated stab in the dark and offer some wrong information again.
Thanks again. The motors are pretty sizeable as they have to pull back a meaty spring, but are quite low geared. Will check the plates next time I am up there and probably come back to ask more questions. G
If there is nothing written on them you could perhaps ask the makers or failing that an auto electrician could probably pop along and measure the current for you. To be honest I suspect that using a 240 volt generator and transformer is likely to be expensive and probably impractical but perhaps you could use the generator with a battery charger to keep the batteries topped up on site. You will need to switch the charger off whilst using the trap though becuase the motors will probably overload it. Hope this helps.
To be honest I suspect that using a 240 volt generator and transformer is likely to be expensive and probably impractical but perhaps you could use the generator with a battery charger to keep the batteries topped up on site. You will need to switch the charger off whilst using the trap though becuase the motors will probably overload it. Hope this helps. The gennys are running on the day anyway, because we have some 240v traps, and we also power up the clubhouse with one. We run the shoot every 2 weeks and are only there for 5 or 6 hours, not really enough time to charge the 15 batteries we use. We have no mains elec on site to leave them on charge so we have to drag them all back to the car park and take them home. At £90 apiece they last a couple of years and for a non profit making club that is a fair outlay anyway. If we can mole a load of cables out to the traps and leave them in situ it will make the setup a lot quicker. Longer term we'd like to get mains power on so any low voltage cabling we did would be ready for that as well. Just on another point of interest, and I know I am opening a can of worms here, would you think that part P applies to power supplied from generators or is it mains only? I'm off to bed now...look forward to the replies to this one!
