Hi all, Sometimes more in the morning after the wife has showered or the tap has been running a while cleaning teeth or something, the water seems to smell really bad! Sometimes lasting till we get home from work! I suppose it could come from the toilet water too. Also if we take water to bed the next morning it can taste funny. Any thoughts? We are getting a new boiler in next week but I suppose binning our old system won't sort it but I can at least ask the plumber to look at while he's there. Thanks in advance! Scott
or bird or squirrel or you live in a spa area where there is a natural sulphur content in the water. or your water authority has messed up the treatment - not unknown. Get your supplier to test it - after getting the bodies out of the loft tank
If the water's alright out of your kitchen sink, start buying bottled to brush your teeth or do it downstairs.
The water tase the next day can be from either tap but the smell is worse from the bathroom! Are you sure this is the water and not a drain problem. My kitchen sink used to smell vile until I cleaned the trap.
Where-abouts are you? Some spa areas do have a slightly odd tang. If it's the drains or traps though they might need seeing to
