I need to fit an extract fan in the bathroom, the only option I have is to extract through the roof. I've been looking at the Versa- Tile, are these easy to install ? Also I am trying to locate the size of them, I have no idea who makes these ? Regards
Hi, yes I fitted one recently, instructions come with it, hardest part is staying on the roof, I would hire a roof ladder at least. Sized to fit most concrete roof tiles, roof vent tiles are fiendishly difficult things to get hold of I found and can be ridiculously expensive..
Mess around with a sound roof at your (and its!) peril. Have a look at Lapvents mechanical extraction fitting for its internally mounted roof vent - it really is the dogs doo daa's. Joatmojo
Thanks for the replies. The Eaves are blocked up at the wall plate so the soffits are inaccessable. Not heard of lapvents??
"The Eaves are blocked up at the wall plate so the soffits are inaccessable." So I assume you have a warm roof then? Because if you don't and your eaves are blocked up you're gonna have a ventilation issue a little bigger than the one you have now.
go with joatmojo i had not seen these before, and could of used them many times, have been browsing the site they are a quality idea
OK, installed one at the weekend bit of a bummer since the felt was quite tight I'll have to see how it goes.
I have retro-fitted 380 in the re-roofs of a hospital complex, and quite a few more in other projects with no difficulty. So long as you slit far anough down the run of underfelt (making another parallel cut lower down if necessary) and recover correctly, you shouldn't have had much of a problem really. Sorry to learn that you had a bit of a struggle - I feel guilty, because I recommended them in the first place. Joatmojo
Joatmojo, It's basically a good product but I think that it's expensive for a bit of plastic. I had to cut away quite a section of felt to get it to slide under the remains of the felt, this left a gaping hole at the botom end. I have pretty severe condensation in the loft and was thinking of fitting some of the non-mechanical versions, problem is that they are expensive (£56 each) and I haven't a clue how many to install, at that price I don't want to be buying more than I need.
the actual unit is not just a piece of plastic though is it derekq. A great deal of thought has gone into its construction and there are many unique safety features - actually, there's quite a lot to it, and it ought to have come in kit form, I think? I'm afraid there would be no 'gaping' hole at the bottom end though if installed properly! However, £56 each does seem to be a bit expensive, is that for just one? To be fair, a single externally fitted type 'tile' vent would probably cost more if you included delivery costs - a single entity is often nearlly as expensive as two or more. If you like, I may be able to help if you could take a few digital shots of the job and get them to me somehow. Joatmojo
Don't get me wrong I'm not knocking them it's a good idea. My only concern is that if I buy say 2 then I need say 6 them it starts to add up. Just found out they are £45 each for up to 10 units. The mechanical extract version is £56 for upto 10 units.
