Hi all, I have built a new timber framed 4"x4" garage at the bottom of my garden and have been a bit naive Unfortunately the pitch of the roof is only around a foot over 5 metres (havn't measured exactly in degrees) and so my plan of tiling it won't work, even in slate As the garage is (in my eyes) something very rustic and nice looking i am loathe just to felt it Any suggestions as to what i could use instead other than a monstrous amount of furring peices? And what would be the minimum pitch for the use of slate/shingles? Thx in advance
Not very big, is it - 4" x 4"............ Joking apart, you can cover the roof with what-ever you want - the low pitch 'only' means that you have no come-back with the manufacturer of the slates/tiles/shingles if there's a problem, (at your risk in other words), - unless building regs are involved - in which case, ask the BCO what he'd approve. From memory, min pitch for natural slate is 22.5 degrees.
Roofing tiles are limited to 18 degrees for most domestic slates at a push, there are some godawful commercial coverings like in steel corrugated sheeting. I have just redone one of my barns which had a 10 degree flat roof. I have refelted it and over lathed it then put red pantiles on top just for appearance. This allows for driving rain. Hope this helps, steven
just a thought - you could do the roof in polycarbonate sheeting like a conservatory so nice and light without any worries on the slope angle.
Quick question, I have to cover a gap that is 5 metres by 6 metres.The roof slopes across the 5 metre stretch. I have been told that I will need to buy polycarb in 6 metre lengths to span the distance with 500mm overhang each end. Is this correct? The only polycarb sheeting that I can find is about 6ft by 2ft. Is it possible to lay the sheets like tiles or slates eg. top overlapping the bottom to allow the rain to run off. Does anyone know of a better way to do it? Any answers appreciated.
Sometimes a revised plan becomes the better I am going to lay turf on the top - perhaps grass-seed it and as a neighbour suggested, some wild flower seeds in with it too I may even be able to sunbathe on it
If you're serious about a green roof, you'd be best to consider sedum rather than turf, as it's considerably lighter being hydroponic rather than soil based. Info here: http://sedumsupply.co.uk/
Hi, I've just had a problem unlike yours. But I couldn't use tiles, too much weight and god do I hate felt.. hate it!!! So I've used waney edge boards 12" wide 20mm thick tanalised... looks the pups nuts. I hadn't sheathed mine but would recommend it for a water tight finish.
