Anyone have experience with the Stiebel Eltron Electronic Instantaneous Water Heater 12.0kW? I'm looking for a water heater to heat two sinks and a shower in my summer house. Is this the right thing to get? I'm trying to avoid having faffy little water heaters everywhere, and just want one heater for the whole space. Anyone else done this before or have any recommendations/tips? thanks
1. Lived in Germany for a while. Stiebel Eltron is a respected make. 2. How are you going to get 53 amp electricity supply to your summerhouse? You'll probably need 16 mm SWA cable - around £7.25 / metre. 3. And how are you going to get rid of the waste water?
@andy48 we are running more power out to the shed and there’s already a toilet out there, so waste water is accommodated. is this water heater the kind of thing that will allow me to put normal shower and sink faucets in? Should it be put up in the crawl space or does it not matter? Thanks for any and all pointers!
You can use a 12kW instantaneous water heater for a really good shower, but it's not appropriate for a bath. Also, you can't use it with a thermostatic shower. It can only be used with a manual mixer. I have mine mounted under the bath behind the bath side panel.
So does it need to sit in the bathroom, or can I put it further upstream and have it heat sink and shower?
You can put it wherever you want, but I'd suggest insulating the hot water pipes if you're doing long runs, as it loses quite a bit of heat ... heat that you can't afford to lose because it's only 12kW and the only way it can get the water to a decent temperature is to restrict the flow a bit. That's why they don't suggest you use it for a bath. It's perfectly OK for a shower though. FWIW, mine heats the water for the shower, the basin and the kitchen sink, but fortunately the maximum run from the bath to the kitchen sink is only about 3m as the kitchen is directly below the bathroom. I have 25mm thick insulation on the hot water pipes and that helps a huge amount.
Super helpful, thank you! My kitchen and bathroom are going to be 2 m apart in a summer house that is only 25 sq m, so I think it will be fine. While you’re being so helpful - did you consider any other brands/products and what made you choose this one above the others? Thanks again.
Apologies, I realise this is a 2 year old thread. I am wanting to install a Stiebel Eltron DCE-X 10/12 Premium, and I can't seem to find any information regarding the flow rate this unit can produce. I understand that it says "2 sinks + shower" but I can't understand what not a bath? If it is able to supply 2 sinks, why not a bath? Surely a bath is achievable as long as you have the flow rate at a reasonable level? My sinks flow rate is roughly 11l/m, couldn't the water heater produce say 7l/m and fill the bath? thanks in advance
12kW means you can only get hot water at low flow or warm water at strong flow. A bath at low flow would be cold by the time it was full.
Thanks for this thread as I want to put a stiebel eltron in my flat. The note on insulating the hot pipes and keeping close to the bathroom was very helpful as I would not have thought of it.
