1 way to 2 way & 2 way to 1 way switching
Discussion in 'Electricians' Talk' started by BettyC.Mattingly12, Jul 14, 2018.
  1. BettyC.Mattingly12
    BettyC.Mattingly12 New Member
    I have a light operating off 2 switches whcih I need to operate off 1 of the switches and a light operating off 1 switch which needs to be operated off 2 switches, can anyone help me with how to convert these light switches, I am unsure which wires to take out and which wires to add
    Thanks
  2. retiredsparks
    It would appear that you are well out of your depth and should not be doing this.
    Electricity can and will will kill you and/or cause fires
    Call in a qualified electrician.
    RS
    KIAB likes this.
  3. unphased
    unphased Screwfix Select
    Sorry OP doesn't make sense.
  4. seneca
    seneca Screwfix Select
    From what I can understand the first one is easy, just remove the unwanted switch, connect 2 of the wires together in a block and keep the third one insulated and then fit a blanking plate in place of the switch. The second one is more complicated as you will need to run a 3 core and earth cable between the two switches.
