1 way to 2 way & 2 way to 1 way switching
Discussion in 'Electricians' Talk' started by refurb, Oct 9, 2003.
  1. refurb
    refurb New Member
    I have a light operating off 2 switches whcih I need to operate off 1 of the switches and a light operating off 1 switch which needs to be operated off 2 switches, can anyone help me with how to convert these light switches, I am unsure which wires to take out and which wires to add
    Thanks
  2. luffo
    luffo New Member
    from experience u r probably better off just adding another switch rather that trying to be clever and swap them over, how how many away do u want the new secondary switch?
  3. refurb
    refurb New Member
    Sorry luffo
    Probably did not explain it well enough, 2 seperate lights,
    first light as 2 switches
    second light as 1 switch
    I want to change the first light to 1 switch and add a switch to the second light
    Any help would be appreciated
    Thanks
  4. George Icbar
    George Icbar New Member
    Don't! Just have a beer and live with it.
  5. utility-shop.com
    utility-shop.com New Member
    I agree with luffo.
    Easier to add than take away in this case.
    Mark:)
  6. Jack
    Jack New Member
    Are these lights and switches in the same room ?
    Would you want to re-use the same switch postions, but to operate the other lights ?
    If so, leave the wiring at the switches alone, and transfer the cables at the light fittings...
    ie from:
    SW1..... LAMP1 .....SW2
    SW3..... LAMP2
    to:
    SW1..... LAMP2 .....SW2
    SW3..... LAMP1
  7. MR DIAZ
    MR DIAZ Active Member
    Any photos ?
  8. techie
    techie Active Member
    2003 ??
