you can google the processes to find out what they are. Putting more memory will definately help as will right clicking my computer-properties-advanced go to the settings tab under performance click the radio button which says adjust for best performance.
Ok, it chust happened again - big time. I was on 'Pricerunner' and tried to bookmark the page. Clicked on 'Bookmark' and the TV started freezing. Got task Manager up and it was Firefox that was running at 98% (100% CPU overall), and it stayed like this for a good 10-15 seconds, with the Bookmark thingy not coming down. Whatthefcuk? Any ideas?
Well as I'm obviously 'admin', take heed and post something <u>un</u>boring or I'll not only obliterate you from this forum, I'll also give you a virus that that'll make you wish you hadn't bought a pc in the first place.
Fair enough. Did I ever tell you about the number of screws I need to remove before getting into my computer?
If you bothered with Google DA - you'd have found there is a known conflict that you are experiencing! ***. I know, try some no-nails in a spare USB hole.
'Tis 3 on one side and 2 on t'other. One on each side has a plastic knurled knob on it so's it can be removed without the aid of a screwdriver, but that's pretty pointless (not literally) 'cos you still require a screwdriver for the remaining screws. What I'm trying to say is there's no point undoing the knurled ones on there own 'cos that won;t get you in to the computer. I usually undo the screwdriver-screws first so's I can then just undo the others by hand which is a surprisingly satisfying thing to be able to do. Were you close, Hunty?
