10mm in pull switch
Discussion in 'Electricians' Talk' started by losingit, Jan 12, 2007.
  1. losingit
    losingit New Member
    Can anyone recommend a brand of 45/50A pull switch suitable for 10mm t&e.I find them a real ball ache.Many thanks.
  2. Stugadget
    Stugadget Member
  3. electric dave
    electric dave Member
    crabtree will take 16mm (just)
  4. fooman
    fooman New Member
    they are all a ball ache :( did one this morning and its hard to make sure you do not strip too much outer sheath off so when you push the switch into the pattress it don't come out and expose the insulater cores.
    right **** design.
  5. losingit
    losingit New Member
  6. 2 wheeled ant
    2 wheeled ant New Member
    Just need one of those extra deep boxes
    Ant
  7. Clark Kent
    Clark Kent New Member
    Ant
    And persistence..;-)
    or should that be patience..:)
  8. C.A.G
    C.A.G New Member
    Click do a 50 Amp pull sw i use them as stander even for 6mm
  9. fooman
    fooman New Member
    the size of the conductors is never a problem for me to get into the screw terminals its getting it all to fit into the deep back box which is the problem :(
  10. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    cores.
    right **** design.
    Aren't you supposed to have ONLY the core and insulation flexing when fitting the switches ?
    ie so that only those parts bend when pushing switch in to the wiring plate.
    If the cable is brought in properly, and directed accordingly, pushing the switch on will not push anything out through the entrance hole.
    Mr. HandyAndy - really
  11. fooman
    fooman New Member
    much
    the
    insulater
    cores.
    right **** design.
    you obviously do not know how un-bendable 10mm cores are.
  12. wally2
    wally2 New Member
    Hi, absolute pain in the rear end, all of them. The best one is the crabtree one, you dont have to worry about the cables in the box. I try to keep showers to 8.5kw so I can use 6mm
  13. sparky Si-Fi
    sparky Si-Fi Screwfix Select
    Have to agree with most, Crabtree is the Mutts Nik-Naks for terminating 6/10mm T+E in a pull switch.
    Ooodles of room and they look good as well me thinks!
  14. wally2
    wally2 New Member
    Hi, One little point you have to remember with the crabtree switch, the terminal screws are sideways on, I have forgotten a number of times & fitted switch in a corner close to wall then realise I cant get the screwdriver in on 2 of the terminals.
  15. Pompey Sparks
    Pompey Sparks New Member
    Have to agree that
    1. Shower pull chords can be a bugg*r to terminate
    2. I am also a big fan of the Crabtree switch
  16. ban-all-sheds
    ban-all-sheds New Member
    When I did mine I found it wasn't too difficult to have enough slack to be able to pull the cable down through the back box, connect it up with it at a reasonably convenient height, and then push the cable back up as I screwed the switch into place....
  17. Stugadget
    Stugadget Member
    The Crabtree one that I recommended
    http://www.screwfix.com/app/sfd/cat/pro.jsp?id=90597&ts=36733
    Is good because you mount the base on the ceiling first and then feed the wires down and the connections ane terminated on the base so there is no pushing wire back up. Then you just screw on the cover. Also the cover contains the neon so when it is removed you can still switch it on and with the live and neutral removed from the shower you can do IR testing no probs.
    Try one I think you will like them.
  18. ban-all-sheds
    But it's round.....
  19. BusterGonad
    BusterGonad New Member
    And so is the moon. Which means????
  20. X
    X New Member
    The moon is a pull switch. ?
