110v Vacuum ("dust extractor") AKA Hoover to use on site
Discussion in 'Tool Talk' started by AlvyChippy, Nov 7, 2017.
  1. AlvyChippy
    AlvyChippy Active Member
    Right chaps, to put bluntly got "hand forced over" and after years of avoiding, new job, that I will be starting midd next week (mainly 2'nd fix), site foreman demands having own dust extraction... bug8er!
    I had Henry (240v - joke of an "pro" vacuum, home hoover is way better), worked in workshop with proper system (240v fully auto "overhead on a pulley"- lovely), also used Axminister (110v supplied) and all as one are pain in the back side. All the hoses, adapters (my tools will need at least 3 types), heavy, cumbersome.
    Had a chippy using own Festool (small) one, but it wasn't up to the job and the price! ... perhaps even more expensive would be OK, being a tight git- just can not justify such expense.
    Honestly WILL NOT care for M or L class or any other class, need one, so it would have "auto take off", 110V, wouldn't be too big and reasonably priced.
    Looking/considering to add on "cyclone separation system", that's another rip off at over hundred moneys, but it makes simple job even more cumbersome...
    Shortlisted towards Sparky, Sealey, Vacmaster and even *might splash out £210" on Fein one.
    (Unless hiring one for this job, but about a month work, will end costing more, than to buy out-right, I thinks)
    Any advice is greatly appreciated,
    Thanks!
  2. Pollowick
    Pollowick Screwfix Select
    There are some nice Nilfisk machines - they do 110v with power take off and switch on take off.
    AlvyChippy likes this.
  3. KIAB
    KIAB Super Member
    Some 110v are restricted to about 1000w for power take off, so rules out some of the larger power tools.:)
    Pollowick and AlvyChippy like this.
  4. Pollowick
    Will always be a problem though ... and if used with portable transformers, they are often limited to 1, 1.5 or 2 kW so allowing for the extractor power, there will not be much left. And cable/flex sizes will be getting rather large.
    My old 230v vacuum/extractor has a takeoff which is limited to 1250 or 1500 W
  5. KIAB
    KIAB Super Member
    My Makita VC2012L vacuum/extractor takeoff says 2000w @ 240v.
  6. AlvyChippy
    Will have a look at ;)
  7. AlvyChippy
    Worrying!
  8. AlvyChippy
    So, if to use separate transformer, "take off" is out of question :(
  9. AlvyChippy
    (Might, just might) get over my makyyta "pet hate", if there is 110v version...
    Any suggestions for actual model's, makes etc?
    Thanks!
    Also, found some "vortex separators" with universal adaptors for under 50 moneys- back on a table option ;)
  10. KIAB
    KIAB Super Member
  11. Broon
    Broon Active Member
    Could try Trend T31A or T35
  12. Broon
    Broon Active Member
  13. Pollowick
    That would mean the cable and circuit need to be capable of 36003700 W or 35 A certainly not a transformer option. And with thos machines at 1200 and 1700 W even using alone would need a 2kW transformer. So, only really suitable for a site where there is a 110v supply available.
  14. KIAB
    KIAB Super Member
    A 110v heater transformer (has a continuous rating, unlike a normal 110v transformer) might be suitable, but not cheap to buy.
  15. Pollowick
    Probably need to be a 5kVA which tend to be rated for short term use at that level and down at around 3.5kVA continuous - probably around £150!
    edit to add:
    A quick search bring up this: https://www.tool-net.co.uk/p-411230...MI6v3Oyb2v1wIVtgrTCh2j-gwQEAQYASABEgLxe_D_BwE
    5kVA non-continuous, 3.5 kVA continuous.
    Fitted with 13A mains plug! So, 13A at 230V => 3000 W How long before the plug and fuse overheat? Or the fuse ruptures regularly when used for short high power bursts ?
  16. KIAB
    KIAB Super Member
    A 5kva Continuous Rated Transformer is close to £300, but needs a 32A 240v supply.:(
  17. wiggy
    wiggy Screwfix Select
    I had the trend t31. Good bit of kit, it can take abuse.
  18. WillyEckerslike
    I have the 240v Nilfisk Aero stocked by our hosts (but bought cheaper elsewhere) which is an M class if used with the correct filter I believe. Relatively quiet - I hadn't realised how noisy my Earlex had become (or always was) and pretty thorough when used with a Mirka Deros. Not had it long enough to really put through its paces but pleased with it so far as value for money. The power take off is 1900w I think but can't check as it's on a job - don't know about the 110v. I have made a dust separator using a baffle system and that works well enough. Cyclones can be bought for less than £20 on Amazon.
    Interestingly I have seen what I think is the same machine dressed as Milwaukee at over twice the price. Now I like my Milwaukee kit but......
  19. KIAB
    KIAB Super Member
    And my Makita VC2012L is identical to the Nilfisk Aero 26 -?, can use the Nilfisk bags in mine, & cheaper than the Makita bags.
    WillyEckerslike likes this.
  20. KIAB
    KIAB Super Member
    Cyclone filter can be bought on Ebay cheaply, got one fixed to a blue plastic drum to use with mitre saw & planer.:)
    [​IMG]
