1200MM WORKTOPS
Discussion in 'Kitchen Fitters' Talk' started by ALMOST PERFECTION, Aug 21, 2006.
  1. ALMOST PERFECTION
    ALMOST PERFECTION New Member
    Hi,
    I am fitting a 1,200mm wide breakfast bar (two 600mm base units back to back). Does anyone know where I can get a 1,200mm wide laminate worktop to avoid two 600mm widths with a joint down the middle. Nowhere seems to stock or make a 1,200mm width (or thereabouts). I live in Bedfordshire.
  2. britishblue
    britishblue New Member
    If you've got two 600mm base units back-to-back under the breakfast bar, where are your legs going to go, when sitting at the bar?
    BB
  3. britishblue
  4. jasonb
    jasonb New Member
    Don't fancy having to lift that one at 1200x4100!!!
    Jason
  5. ALMOST PERFECTION
    Sorry, misled you. More a 1,200mm wide by 2,300mm long work surface than a breakfast bat that you sit at.
  6. ALMOST PERFECTION
    BB - thanks for the advice
  7. Boff
    Boff New Member
    Only people that I know of that make them are Getalit which are available on the site posted above and £290 is a very good price. Getalit will make them up with either 1 post formed edge (worktop) or 2 (breakfast bar) but expect to wait around 5 weeks to get them from Germany.
    Be warned - they are seriously heavy :)
  8. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    Is this for yourself or a job ?
    I was thinking, you can't reach over 1200mm, so you would need to walk round etc.
    Wouldn't an idea be to fit 2 worktops(breakfast bar-double edged) with a walkway between them, then you could walk through and access both tops.
    Leave the backs off the units and be able to reach down for items in the cupboards. Heck, you could even fit access doors to the ends of the aisle.
    Just thinking aloud...
    Mr. HandyAndy - really
  9. ALMOST PERFECTION
    Thanks everyone for the advice - really helpful
  10. STGO
    STGO New Member
    yes andy, and a little door to narnia,
