12V Halogen lamps
Discussion in 'Electricians' Talk' started by ajmoore, Feb 10, 2004.
  1. ajmoore
    ajmoore New Member
    I am going to install some 75mm low voltage lamps in my utility room. The room measures 8ft * 8ft. I have got 3 35w lamps would this be sufficient to light this area. Is there any way of working out what the number of lamps reqd. I have never installed any of these before so any advice would be gratefull.
    Thanks
    AM
  2. sparky Si-Fi
    sparky Si-Fi Screwfix Select
    Hello
    Theres nothing wrong in going mains halogen just as another option being its in your utility room,cant see a utility room classed as a special location.
    Therefore not needing to muck about with transformers,but choice is yours,but if you do go with SELV use 50W lamps and a transformer for each lamp with a 60Va rating.
    Hope it helps
