135 corner posts
Discussion in 'Kitchen Fitters' Talk' started by abitclueless, Sep 9, 2010.
  1. abitclueless
    abitclueless New Member
    Please help. I am fitting some base units diagonally across a corner so the angle is 135 not 90. I need to fit a corner post but cannot work out how to fit it. It only seems to work at 90. Any suggestions? Oh the kitchen came from Howdens and they say that it is the only corner post they do.
  2. sinewave
    sinewave Screwfix Select
    You'll have to 'manufacture' your own using whats available from Howdens to match.
    Ask a proper joiner if it's beyond U! ;)
  3. Captain Leaky
    Captain Leaky New Member
    Correct! Corner posts are for 90 deg corners!
  4. blueassedfly!
    blueassedfly! New Member
    you need to use some plinth and cut it at 27.5 degrees along the joining edges then cut them to 720 in height by whatever width you actually need to complete the join.all you need is a small table saw, a chopsaw and a biscuit jointer and your away!
    now you see why real kitchen fitters earn the BIG BUCKS! ;)
  5. blueassedfly!
    ps dont forget the glue and clamps!!!!
  6. russ295
    russ295 New Member
    i normally use a wall decor, its already 720mm and saves edging it.
    russ
