16mm meter tails in what size conduit?
Discussion in 'Electricians' Talk' started by Strima, Feb 25, 2012.
  1. seneca
    seneca Screwfix Select
    Difficult to say for sure without seeing it Strima but I think if I were doing it i'd make every effort to put a 3 core 16mm swa sub-main in  with a switch-fuse at the origin.
  2. Strima
    Strima New Member
    Cheers Seneca.  Never even crossed my mind to stick a switched fuse in, must be the beer taking effect.
  3. Lokkars Daisy
    Lokkars Daisy New Member
    *** Strima , you arn't a practising electrician , are you, I wondered at your first post, but kind as I am I went along , hoover the more I read the more I realise you should not be carrying out this work
  4. Strima
    Strima New Member
    Cheers for the replies all.
    Obviously some people on this forum think they are as big and important as thier post count.
  5. Lokkars Daisy
    Flippin Blimey JP!
  6. Lokkars Daisy
    Ooh ,not really Strima, but seriously though it does sound like you are new to this, reading stuff in a book and then coming on here to see if what you read and your interpratation is correct, but hey that's just my gut feeling, ap[pologies if i got it wrong
  7. J.P.
    J.P. New Member
  8. Lokkars Daisy
  9. J.P.
    J.P. New Member
  10. J.P.
    J.P. New Member
    LD ive stuck a topic in the Plumbers Forum with ref to a gas pipe - you and a lot of the people on the forum are pretty flexible - any chance of you or others avving a dekko and commenting? bit stuck on that one tbqh.
  11. Lectrician
    Lectrician Screwfix Select
    Your "copper pipe" isn't MI cable is it?
  12. Strima
    Strima New Member
    Hadn't even thought of MI cable, I'd have to strip part of the box out to have a look.  I've never worked with MI cable but after a quick google it could be.
  13. Lectrician
    And if it is, it is likey fine in terms of its size ;-)
  14. Strima
    Strima New Member
    Thanks Lectrician, I'll test the cable and hopefully everything will be good.
