17th Edition Consumer Units.
Discussion in 'Electricians' Talk' started by The Happy Builder, Apr 5, 2008.
  1. The Happy Builder
    Just looked through the new Screwfix catalogue which will take us past the start of the 17th edition and unless I'm mistaken only the Wylex Consumer Unit will comply, to use any of the other brands will require RCBO's which are not available from Screwfix.
    Screwfix may like to get some advice from an Electrician before preparing the next Catalogue!
  2. Sherlock Ohms
    Sherlock Ohms New Member
    Electricians don't buy that * from Screwfix.
    It's for DIYers and Jacks. ;)
    [Edited by: admin4]
  3. yogi972
    yogi972 New Member
    so why are electricians on here talking.....
  4. Sherlock Ohms
    Errr, because they are here <u>talking</u> yogi. ;)
    Not buying "17th edition" CU's.
  5. yogi972
    yogi972 New Member
    but why not talk in another forum then....
    I buy loads from s/f and only got into this forum because of doing so...
    not because I was randomly looking for a forum to join..
  6. Lokkars Daisy
    Lokkars Daisy New Member
    Which one is it ?
    All those consumer units might comply ,it just depends on the circumstances
  7. Sherlock Ohms
    Well that's you yogi.
    I personally found the forum on google long before I bought anything.
    Probably because I prefer to get better quality stuff for cheaper, from a real electrical wholesaler. ;)
  8. Lokkars Daisy
    So what percentage does your wholsaler give you off Wylex Sherlock?
  9. yogi972
    yogi972 New Member
    ohhhhhhhhhh
    a bit ******
    well... for me to order online, eg.sun, and get the goods monday, suits me fine saves me traping into town (im in the sticks) to my wholesaler. I only get certain things from each ;)
  10. Sherlock Ohms
    Wylex Sherlock?
    They don't have Wylex to be fair. It's MK, Crabtree or own brand.
    The Crabtree "17th edition" are about 65 squid.
  11. Sherlock Ohms
    > ohhhhhhhhhh
    a bit ******
    certain things from each ;-)
    Good for you yogi. :)
    The rep at my wholesaler will also send anything to my house/site the next day. By 8.30am if I want it. And will beat any quoted price. :)
  12. yogi972
    yogi972 New Member
    sounds good, any around the midlands then??
    (sorry s/f)
  13. rekoj
    rekoj New Member
    or own brand.
    Wow, great, well stocked wholesaler that Sherlock.
  14. Sherlock Ohms
    Why do you need Wylex when you have Crabtree and MK?
  15. rekoj
    rekoj New Member
    Just jestin with ya Sherlock. The alcohol dost flowest with great haste this fine evening. Its bleedin snowing outside, would you adam 'n' eve it!!!
  16. JP.
    JP. Screwfix Select
    What is the current vision of a 17th Edition DB?
    6 ways are needed for the main switch and 2 Rcd's..no escaping that..
    What are you lads doing with the rest of the ways?
    A 20 way min DB is indicative in most scenarios?
  17. prosparks
    prosparks New Member
    escaping that..
    Lots of places have old wylex with 1 ring, 1 lights, 1 DHW and 1 cooker.
    But to retrofit dual RCD it still can be tight on space.
  18. fabregas
    fabregas New Member
    A 16th edition DB until July
