18mm hardwood ply
Discussion in 'Carpenters' Talk' started by mrppp, Jun 27, 2017.
  1. Pollowick
    Pollowick Screwfix Select
    You have 44 sq M - so to allow for waste say 50 sq M. With 6" boards there are 7 in a metre of width which means you will need 50x7 linear metres which is 350 linear metres. You should be able to source it from a decent timer merchant at around £1.50 to £1.80 per metre inc VAT. That works out at £525 to £630 with plenty of spare.
    Having a look around - http://www.builderdepot.co.uk/tongue-groove-flooring-22mm-x-150mm-sold-per-metre.html is £1.57 inc.
    And make sure you visit and see the quality before you order.
  2. Jord86
    Jord86 Screwfix Select
    Builderdepot.co.uk 18mm t+g chipboard p5 £7.68 a sheet Inc vat, 44m you need 31 sheets, add 10% if needed for waste, 34 sheets, equals £261.12 if my dubious maths is correct.
    longboat likes this.
  3. mrppp
    mrppp Member
    I would never use chipboard, I was originally looking at 18mm plywood, TP do
    Redwood Tongue and Grooved Flooring Standard Flooring 20.5mm x 144mm at £920 +vat ( 350 linear metres) doing in ply 16 sheets £480
  4. Pollowick
    You should be able to get a good discount on those TP prices as a starter.
    Where in the country are you?
  5. mrppp
    mrppp Member
    Home Counties near Windsor
  6. Pollowick
    Have sent you a message with a possible supplier to call.
    mrppp likes this.
  7. mrppp
    mrppp Member
    When fitting these is it one screw per joist per board or do you put two screws in a board on each joist? (floor boards)
  8. KIAB
    KIAB Super Member
    I've seen peeps rip down 25mm ply to use as floorboards,& some using 15mm or 18mm sheets again ripped down & laid over a concrete floor, some finishes looked darn good.
  9. Pollowick
    TWO ... just make sure you know exactly where any pipes and cables are.
    mrppp likes this.
  10. Mr Rusty
    Mr Rusty Screwfix Select
    44sqm is a lot of screws - prob not far off 2000. If you use a cordless and set the torque your wrist will know about it at the end as every screw puts a little twist on it. One of the best reasons to buy/hire a collated screw gun - they are depth adjusted not torque adjusted - no wrist strain.
    Also DO make sure you use flooring screws. These will have either a plain shank (no thread) under the head, or sometimes a short extra thread at a different pitch. If you use a fully threaded screw the boards will not pull down tight and will creak.
    Joe95, Pollowick, mrppp and 1 other person like this.
  11. Pollowick
    With
    around 310 to 320 linear metres to install, at 400 centres there will be around 6-7 screws per metre to allow for ends and joins which suggests 1860 to 2240 screws which ties in with your estimate Mr R.
    Only when you have used a collated screw gun do you really appreciate the benefits - time, speed, consistency, fatigue, blisters, sprains ... I can probably insert 100 collated screws in the time it takes to do 10 with a normal electric screwdriver - ad they will all be at 0.5 mm below the surface.
  12. Mr Rusty
    Ain't that the truth!! :p
  13. mrppp
    mrppp Member
    I best factor in getting one then
  14. Pollowick
    Mr R can provide a link to his good value budget one! Or the one I have is a Fein M-gun at around £250
  15. mrppp
    mrppp Member
    Any link appreciated for one suitable to screw in 18 or 25mm boards
  16. Mr Rusty
    I just had a look and there don't seem to be any left :(. When I got mine there were a load of discontinued Senco DS275AC (mains) on ebay at £80-90 . Old model >3 years out of date but works just fine. Only issue with this particular model is that the bits are an odd/unique size and you have to hunt them down. (I have a stock now that will see me good.) I wouldn't buy a cordless version of this model even if you find one - too old - the batteries won't be fresh.
    I'm pretty sure all the drivers will be suitable for floorboards. Mine takes from 35mm to 75mm screws - I've been using 35mm for PB and 55mm for boards
    best prices I can see are
    http://www.kelvinpowertools.com/senco-ds5525-auto-feed-screwdriver-c-36-p-8235
    or
    http://www.powertoolworld.co.uk/mak...bNgt543kYrEoyamSvaIJ57id4Xdqw_TqDkaAkKY8P8HAQ
  17. Pollowick
  18. Mr Rusty
    +1 for Timco - perfect for the job
  19. mrppp
    mrppp Member
    And what driver will be suited for these?
  20. KIAB
    KIAB Super Member
