19mm/20mm Electrical trunking in grey
Discussion in 'Electricians' Talk' started by Possom, Sep 13, 2019.
  1. Possom
    Possom Member
    Is it possible to obtain 19mm/20mm round tube electrical trunking in grey colour? I'm only been able to locate it in white.
    Thanks!
  2. dobbie
    dobbie Screwfix Select
    20mm plastic conduit is only available in white and black.
    Galvanised metal conduit is available which would be the nearest to grey, depending what the use is, you would need the proper tools for it, although there is a version with grub screws rather than threading.
    WillyEckerslike and Possom like this.
  3. KIAB
    KIAB Super Member
    What you wanting to use it for.
  4. KIAB
    KIAB Super Member
    Possom likes this.
  5. robertpstubbs
    robertpstubbs Screwfix Select
    Some of the PMA flexible conduit is grey.
    Possom likes this.
  6. dobbie
    Possom likes this.
  7. Possom
    Possom Member
    I have an electrical socket on an unplastered breeeze block wall which has white plastic conduit from the floor up to the socket. This is particularly unstylish and a grey conduit would at least blend more in with the colour of the blocks.
  8. KIAB
    KIAB Super Member
    Paint it grey.:D
    nigel willson and Possom like this.
  9. Possom
    Possom Member
  10. robertpstubbs
    Paint the wall white to match the white conduit.
  11. dobbie
    Possom likes this.
  12. Possom
    Possom Member
    Thanks very much dobbie.
  13. Tony Goddard
    Tony Goddard Screwfix Select
    CONLOCK is the tradename for galvanised fittings using a grub screw clamp, ideal in situations where you don't have access to a threader and bender!.
    Various sites sell them including ebay
    Possom likes this.
  14. robertpstubbs
    It will lose its shiny finish and become dull over time. There is some possibility of rusting near cuts.
  15. dobbie
    That is what Galvafroid is for, if required.
