1amp ring spotlight camera off lighting circuit
Discussion in 'Electricians' Talk' started by Mrbud, Mar 21, 2019.
  1. Mrbud
    Mrbud New Member
    Hi,
    I've just taken down my old pir light from in the porch and wanted to replace it with the 1 amp ring spotlight camera. II' a bit lost on how to wire the core and earth wire to the wire when I take the plug off. I want it on the lighting circuit as it had its own dedicated switch inside to turn it off if I wanted. I will connect writes inside a good junction box.
    Thanks for advice on advance
  2. seneca
    seneca Screwfix Select
    Use a fused spur which will double up as your junction box.
    Mrbud likes this.
  3. Mrbud
    Mrbud New Member
    Cheers seneca. Would you know how to wire the 3 core and earth cables?
  4. seneca
    It will be obvious when you look inside, live in, neutral in, live out, neutral out, the latter two are usually marked "load".
  5. Mrbud
    Mrbud New Member
    Cheers for your time. So I know the brown will be live still, in the plug the neutral will be blue but from the 3core and earth which cable is neutral etc. Thanks afaga :)
  6. JP.
    JP. Screwfix Select
    Hmmmmm..''3 core and earth cables''
  7. seneca
    Brown live, Blue neutral, unless it's old cable in which case it will be Red and Black.
    Mrbud likes this.
  8. Mrbud
    Mrbud New Member
    Sorted. All wired up and working. You are a top person!!! Thanks
    seneca likes this.
