1st fixers will love this
Discussion in 'Carpenters' Talk' started by handcraft, Jan 21, 2008.
  1. handcraft
    handcraft New Member
    im aware about the warranty completely forgot about insurance may have to look into that
    or just be careful
    lee (joke)
  2. dirtydeeds
    dirtydeeds New Member
    theres a reason why worm drive saws arnt avaliable in this country, its been hinted at above
    they arnt CE approved for two reasons at least
    no kerf knife and no brake
  3. chip off the block
    chip off the block New Member
    alot more of the blade is showing on alot of these saws which makes it alot easier for those compond cuts in roofs. In my opinion that makes it safer to use as you are not messing around with the gaurd to start the cut but then a stupid rule stops us using them
  4. handcraft
    cheers cotb that is exactly what i want it for ease of use its either that or you have to use an oversize saw which i dont like doing
    lee
  5. chip off the block
    how much did you pay for it and when are you expecting it?
    I want to get 1 and maybe a prazi beam cutter to use with it
  6. handcraft
    ive stopped the order now i asked them to hold it im gunna get it from internationaltool but im still not sure bout the power cable maybe you could help ive seen those beam cutters they look mad
    lee
  7. chip off the block
    i would go for a regular saw like the skil then if the cable gets damaged you can replace it. I think i will get the 8 1/4 skil with the 60 degree bevel as i think it will be the most useful but will also look what saws are compatable with the beam cutter
  8. handcraft
    im mainly going for the bosch because it has arafter hook and direct connect but if the cord gets damaged i should still be able to repair it safely as when i get it im going to have to re wire it to make it 110 volt
    lee
    i know it seems like a bodge but several people have recommended this
  9. chip off the block
    you can get the bosch without d connect
  10. handcraft
    yeah i know but i would still have to put a 110 plug on it wouldnt i
    anyway i like the idea of d connect
    lee
  11. chip off the block
    rigid make a saw with a hook aswell
  12. handcraft
    where did u find the rigid ?
    lee
  13. chip off the block
    the skil includes a hook
  14. chip off the block
    on the riged main site
  15. chip off the block
  16. handcraft
    the skil has a hook ? ahh it also has 60 degree bevel are you trying to talk me out of the bosch lol ?
    lee
  17. chip off the block
    well read some reviews and see what you think.
  18. handcraft
    well the skil was my first choice i was also told about porter cable but when i saw the bosch i thought it looked the dogs i will read a bit more then decide
    lee
    how bad do you need the prazzi do you do oak beams and alike
  19. chip off the block
  20. chip off the block
    i would check about the hook think but alot of places sell it with a hook
