Hi, I do a bit of woodworking from time to time, mainly rough stuff, nothing fancy. I need to make a load of wooden boxes out of 1/2" and 3/4" ply, just simple screwed and glued. I'll use a circular saw to cut the ply and have had much better results when cutting against a strip of metal clamped to the top of the ply with G clamps. Turns out you can buy these and they're called "guide clamps" - funny that. Anyway, the longest I can find is 1.2m long but I definately need to make cuts along the long edge of a 4x8 board. Where can I get a longer guide clamp from? Many thanks, Dave
50" is as long as I have seen. If you want longer than you will need a guide system such as the festool or maffel but they really need separate clamps. Axminsters do a 2895mm long rail that has two sliding bits that allow you to clamp it without separate clamps but its not as easy as the cam locks on the guide rails. Jason
hi skinny d, you could get a plasters feathedge at 2.4m long and clamp on with some clamps as jason be says a plune cut saw have guide rails which is a £££ option as you say ' rough stuff ' a feathedge may be the way to go wth two clamps or even a straight piece of timber, have to be straight though!! hope that helps evo nut
Hi, thanks for the super swift replies. I currently use a plasterers feather edge clamped on but find that the clamps get in the way of the saws motor if I saw with it on the same side as the edge. I'd seen the guide clamps but just wondered if there were 8' ones like my feather edge. I'll have a look at the axminster system as sometimes I dont keep enough sideways pressure onto the edge and I dont get a straight cut (only once or twice). Looks like having a rail and a carriage on it would work nicely. Many thanks, Dave
Axminster do 2 models a basic rail http://www.axminster.co.uk/product-Axminster-Cutting-Guide-21753.htm and if you are prepared to attach your saw to a base http://www.axminster.co.uk/product-Axminster-Portable-Panel-Saw-System-369292.htm
Hi, I like the look of the basic one , suits me nicely as I can collapse it in to two parts for putting in my van and will make cutting across the short edge of a board nice and easy. Just wondering how thick it is as I'd like to be able to cut with the rail under the body of the saw at times? Cheers, Dave
Just wondering how thick it is as I'd like to be able to cut with the rail under the body of the saw at times? Cheers, Dave I don’t think the technical guys at Axminster have a policy of, publicly flogging or boiling in oil potential customers who ask questions regarding there products.
http://www.toolshopdirect.co.uk/item.php/site/froogle/sn/CGS%2FPRO8 How about this one,has 2 guides that i assume you fit to your 2 favourite tools and clip these into a slot on the clamp or you could throw them away and just use your tool up against the guide
Next time you buy a sheet of plywood, rip a 150mm wide strip off the side and hey presto you have the perfect straight edge for next to nothing.
Next time you buy a sheet of plywood, rip a 150mm wide strip off the side and hey presto you have the perfect straight edge for next to nothing. The OP as been told that opion by a number of members, but he says the board is too narrow and his circular saw keeps hitting the clamps. Its seems a wider board and his clamps turned upside down is not hi-tec enough.
I reckon thats what I'll do for now Cabinet. I'll see what axminster say about their 2.5m thingy. Cheers for all the info, its spurred me on a bit with this box making and there are some interesting videos on you tube on woodworking and festool kit and stuff. Dave
Reverse cut right to left with the other edge of the saw against your 150mm guide piece. You don’t have to reach over the board either then... ...unless you’re a left hander ZZZ
http://www.taunton.com/finehomebuilding/videos/index.aspx?id=69064&c=2 This shows how to make guides.
Cheers two by two, I watched this video then made one this morning and have used it all day for making my boxes. Excellent and does exactly what I want. Many thanks, Dave
