Morning guys...basically is it ok to plug in a 2.7kW fan assisted oven into a kitchen Ring Final? (it hasn't got a plug on it)..thanks in advance for any replies which maybe forthcoming..
Have a look on e-bay. It is still possible to get an adapter for a bayonet light allowing you to plug your cooker into the lighting circuit. You will have the added benefit of being able to turn off the cooker at the same time as the light when you leave the kitchen.
i wouldnt, could overheat the plug, + i seem to remember hearing that any load 2Kw & over should really be on a dedicated supply. i would still say that your oven is to large to be taken from a ring
yes and no, as im sure you know JP. You can justify doing it if you want, and you can justify not allowing it if you want. 433.1.5
i wouldnt, could overheat the plug, + i seem to remember hearing that any load 2Kw & over should really be on a dedicated supply ------------------------ That's correct, I think you know this really JP?
My apologies guys..the oven is 2073 watts and not 2.7kW as stated. Thanks for all your replies, all most appreciated..
Even at or just over 2Kw I wouldn't put a cooker on a ring circuit through choice JP. Dedicated circuit is much better, even where it does have a plug on it.
Yes JP shove it up your backside if you like How many times has every question been asked and you got involved? virtually everyone like So gives us all a break and stop being a pratt
