2" Bath Overflow Problem
Discussion in 'Plumbers' Talk' started by RizlaUK, Nov 11, 2018.
  1. RizlaUK
    RizlaUK New Member
    Hi,
    I recently ordered a new bath and it come pri-drilled with the waste/overflow. The problem i'm having is, the pri-drilled hole for the over flow is 2", where my overflow connector is 1.5". This means when i tighten it all up, the washer slips and doesn't create a water tight seal. I've looked around to maybe source a 2" overflow but they are hard to come-by. I was hoping somebody more knowledgeable could suggest the best course of action.
    Thanks a lot.
  2. KIAB
    KIAB Well-Known Member
    Most overflows are 1.5",you will find a lot of the overflow bath central fillers use a 2" or larger hole.
    [​IMG]
  3. The Teach
    The Teach Well-Known Member
  4. Isitreally
    Isitreally Well-Known Member
  5. RizlaUK
    RizlaUK New Member
    I think that is exactly what i need, thanks!
    Yes there are 2 holes on the top for taps.
    I think i will order what The Teach suggested, unless there are any other suggestions.
    Thanks for the replies.
    Regards
  6. The Teach
    The clicker (click clack) o_O Waste plugs work well but in a bath tub can be bothersome if that end of the bath is used as a shower or when laying back in the bath tub and your heel touches the clicker allowing the bath to drain :(.
    Pop up waste waste systems also have large overflow flanges 65-70mm
