2 cylinders linked together
Discussion in 'Plumbers' Talk' started by Total Plumb, Aug 24, 2010.
  1. Total Plumb
    Total Plumb Member
    Hi
    I have a customer who has the tank and cylinder in the loft. The problem they have is that they only have a small cylinder in position and they are not getting enough hot water. I cannot fit a bigger cylinder in due to the height of the header tank (And it cannot go up any more). I have suggested a horizontal cylinder then we can gain double the literage but the price is a bit step. Dont mention a combi because they have just had a new boiler installed. They have asked me to add another cylinder on to the system so they would be working side by side. Does anyone have any info on this set up and if it can work as I cannot see how. Antother plumber has quoted to do this set up. I cant see how it would work.
  2. Captain Leaky
    Captain Leaky New Member
    Usually in this situation it is more cost effective to fit an electric under sink water heater in say the kitchen and maybe an electric shower in a bathroom or add a separate direct cylinder run by an immersion...You obviously could convert the whole system to unvented but that would probably be too expensive?
  3. Total Plumb
    Total Plumb Member
    Im damned if I do and damned if I dont. Have you ever seen a 2 cylinder set up Leaky??
  4. Captain Leaky
    Yes, I have even put them in, usually you need 1 x 3 port and 2 x 2 port valves controlled by individual tats, a bypass too.
    Too be honest it's more hassle than it's worth.
    Either
    A) convert to unvented - then the cylinder does not need a header or can go elsewhere or
    B) Add supplemental HW from alternative sources as suggested.
  5. Captain Leaky
    stats! not tats! :)
  6. sinewave
    sinewave Screwfix Select
    I prefer Paps me sen!
  7. Captain Leaky
    Mammys Baps for me!
  8. sinewave
    I prefer the younger firmer variety TBH!
    Mammy's will do later on when I've worked up an appetite! ;)
  9. Captain Leaky
    * This * more your kinda thing Sine?
    [Edited by: admin]
    [Edited by: admin]
  10. Captain Leaky
    spoilsports! :(
  11. Captain Leaky
    'twas a delightful shot of that cleaning lady - aggie - in the pool in IACGMOOH!
  12. G Brown
    G Brown New Member
    As advised, 1 3 way and 2 2 way valves each controlled by a the cylinder stats - then find a competent electrician to wire them up!
  13. heatyman
    heatyman Well-Known Member
    Thinking outside the box, take your larger cylinder, lay it horizontal,with the normal cold feed connection pointing upwards, put your cold feed into the normal outlet and use the normal cold feed connection as your outlet. Have used this configuration on boats where height restrictions are also a problem. may not recover as quickly and you need a couple of stands, but saves all the complicated valve and wiring.
  14. Captain Leaky
    It wil probably collapse!
  15. palavaman
    palavaman Well-Known Member
    It will probably collapse, is being nice:p
    it shall collapse. In applying UR theory, did you consider Stratification in cylinders?
  16. palavaman
    If horizontal reqd, why not try here
  17. Captain Leaky
    The best solutions are usually the simplest ones! Horizontal cylinders are never very good. Just add additional hot water sources to reduce the demand on the cylinder.
