2 down lighters or 4 ?
Discussion in 'Electricians' Talk' started by Movieman334, Sep 24, 2021.
  1. Movieman334
    Movieman334 Member
    Hi guys I wanted to ask you advice do you think I should go with two down lighters or 4
    If I went with 4 they would be weak but more for symmetry rather than because it need 4
    Or
    Do i go with 2 down the middle .
    Dimensions are
    Width of room 132cm length upto a curve in ceiling 120cm
    Any thoughts greeatful appreciated IMG-20210924-WA0004.jpg IMG-20210924-WA0003.jpg
  2. Roys
    Roys Active Member
    Go three
    Joking aside I put three in my bathroom which I imagine would be a similar size, and it is just right. Three straight down the middle.
    Movieman334 likes this.
  3. MGW
    MGW Screwfix Select
    Mothers wet room I planned on four, one was integral with the extractor, the extractor was swapped so ended up with three and they were fine.
    Down lighters depend on high ceilings and light colours to work, your ceiling do seem high enough and the tiling is very light so see no problems.
  4. Comlec
    Comlec Screwfix Select
    You might want to tidy up the wiring when you finally fit the lamps.
    There should not be conductors showing outside the connection box.
    Good luck with your project
    ElecCEng and Movieman334 like this.
