2 out of 12 rads are cold?
Discussion in 'Plumbers' Talk' started by alwaysworking, Mar 21, 2008.
  1. alwaysworking
    alwaysworking New Member
    Hi,
    Guys, have got 2 rads out of 10 that for some reason are not heating up. The pipes to the TRV,s are hot but the hot water doesnt seem to be passing through.
    Is it possible the TRV's have both gone at the same time. Rads have been bled...
    Any ideas.
    Cheers
    AW
  2. RPM
    RPM New Member
    have you taken the head off and had a look if the pins on them have stuck, martin
  3. alwaysworking
    Thanks for the reply Martin, I havent removed the TRV yet as I didnt want to interfere unless I knew what I was looking for. I'll remove tomorrow and check the pins. Is it likely the hot water will come through when I remove the TRV and if it does, does that prove the valve is faulty.
    Cheers
  4. Captain Leaky
    Captain Leaky New Member
    when the head is off GENTLY pull the pins up, if they stick down then the rads stay off - for goodness sake don't yank hard on the pins - some come right out :)
