Hi all had a kitchen extention done so half is wooden flooring the after is concrete now i want to tile the floor is it going to be a problem tiling where the wood floor meets the . Is it best work it so the grout joint is at that point or put a full tile right over it.
Work the setting out a full tile either side of the joint. Then, Use an expansion joint over the joint between the different substrates. Either silicone the joint rather than grout, or get an expansion profile from schluter etc
