2016 Renault Trafic
Discussion in 'Car and Van Talk' started by Andrew Spence, May 30, 2019.
  1. Andrew Spence
    Andrew Spence New Member
    My trafic has one side light that always comes on when van is started. This is even when the lights are turned off, is there any reason for this?
    TIA
  2. Bollerks
    Bollerks Active Member
    Yeah, it's French!
    kitfit1 and Astramax like this.
  3. Astramax
    Astramax Super Member
    Yes the other ones blown.......They should both be on.
    Andrew Spence likes this.
  4. Andrew Spence
    Thank you will check other bulb
  5. kitfit1
    kitfit1 Screwfix Select
    Good job it's not Italian...........................nothing would happen in that case :D
  6. goldenboy
    goldenboy Super Member
    I think it might be an indicator fault.
  7. Andrew Spence
    Could you explain please why it could be an indicator fault?
  8. Astramax
    Have you not you sorted it yet! the day time running light has blown or has a faulty lamp holder.
  9. Andrew Spence
    Looked at the other bulb and that seemed ok so was thought it was something else causing it.
  10. Astramax
    Sounds like a bad connection....................try a replacement bulb first.
  11. Andrew Spence
    OK thanks
  12. goldenboy
    On some french vans if you leave the indicators engaged when taking key out it leaves one headlamp on.
    So a single headlamp staying on might be linked
