20v neutral to earth
Discussion in 'Electricians' Talk' started by Kg86, Feb 13, 2018.
  1. Kg86
    Kg86 New Member
    Hi there
    Gas engineer came to look at the boiler and was measuring 20v between neutral and earth on the kitchen ring main, boiler is fed from a spur on this, is this just a case of removing the neutrals from the cu and splitting the ring to trace the fault, ring covers all sockets in the downstairs. Any pointers would be appreciated.
  2. JP.
    JP. Screwfix Select
    Check earth Kg..is it patent?
  3. Kg86
    Kg86 New Member
    Sorry not sure what you mean by patent Earth. Used to working on boats so domestic stuff is pretty interesting without a drawing
  4. retiredsparks
    Patent ?...looks like you spent too long in Hampstead with yer fancy friends...
    RS
