Hi all,
I was hoping someone may be able to help.
I purchased a property this summer that has had a kitchen extension done 5 years ago. The extension is basically 1 wall with a slanted roof which has widened the kitchen.
All seemed fine with paperwork & survey etc but this week a 2cm gap has appeared between the skirting and hardwood floor underneath the radiator and some of the spacing in the floorboards are now a bit wider.
I’ve read about the hardwood floors shrinking in winter due to humidity which may explain the wider spacing but am very concerned about the gap.
No signs of a leak, water pressure is fine, boiler pressure is fine and the radiator is still functioning as normal.
does anyone have any thoughts? Any help would be greatly appreciated
