3 gang 1 way wiring help
Discussion in 'Electricians' Talk' started by Matthew Jedd, Aug 2, 2020 at 5:05 PM.
  1. Matthew Jedd
    Matthew Jedd New Member
    Hi,
    Got myself a 3 gang 2 way switch (however using as a 1 way), I thought it would be a simple job but ended up unscrewing the current light switch and I’m totally lost. Any help would be appreciated.
  2. Bazza
    Bazza Screwfix Select
    Yes, on you old switch you have a red wire that connects to a COM terminal. This is the live feed in. Connect this to the COM1 terminal and than use the short brown wires to connect this to COM 2 and 3.
    Now you are left with three black wires. These go up the three L1 terminals on the new switch. Sorted
    Matthew Jedd likes this.
  3. terrymac
    terrymac Screwfix Select
    Don't you mean two black and one red
    Bazza ?
  4. Bazza
    Oh yes. Soz. Must go to Specsavers
    terrymac likes this.
  5. Matthew Jedd
    Sorry I think I’m being stupid here. Have I got this right.
    Red (currently COM) to (COM1)
    Brown wires connect to COM1/2/3
    now I’m left with red (currently L2), 2 black (currently L2 & L2). You’ve mentioned these should be inserted to L1 terminals however I only have 2 L1 terminals on the new switch?
  6. terrymac
    You have L1 1 and L2 1 and L3 1.
    So the two blacks and the other red go ,one to each of the above.
  7. Matthew Jedd
    Great, thank you both!
