300mm flipper return panel required?
Discussion in 'Plumbers' Talk' started by rkc86, Dec 6, 2021.
  1. rkc86
    rkc86 New Member
    1400x700 tray with 900 screen (well, 1350ish as tiled over tray). You reckon I need the panel at the end? Thanks
  2. pppmacca43
    pppmacca43 Super Member
    You’ll get a bit of splash, I’ve got similar size shower and do, but a mat should catch the worst. If I were you I’d see how u get on and add the flipper screen later if you feel u need it.
    GoldenArches likes this.
  3. GoldenArches
    GoldenArches Member
    Nope….. but what sort of shower do you have? Rain or the other type?
  4. rkc86
    rkc86 New Member
    Both rain & handheld. Not tested it yet. Fitter asking if I need it before he goes this week. Just seeing if the pros outweigh the cons - have the extra water protection or the awkwardness to keep moving the panel for entering & leaving the shower
  5. GoldenArches
    GoldenArches Member
    Can always fit retrospect. I’ve got an open shower, it’s fine.
    pppmacca43 likes this.
  6. GoldenArches
    GoldenArches Member
    You will put down a foot mat so it will be ok
  7. pppmacca43
    I’d wait if I were you, if u find u need one then get it fitted but ideally it’d be better if it is ok without it, it’s just more seals and hinges to go mouldy, or break etc
  8. rkc86
    rkc86 New Member
    Oh I have it. Just sitting there waiting on a decision. I can either have it fitted by this week or return it :)
