350m 32mm MDPE pipe
Discussion in 'Builders' Talk' started by wiggy, May 17, 2019.
  1. wiggy
    wiggy Well-Known Member
    Evenings gents. What's the best way of running the pipe. 2x reels 150 and one at 50
    Stick it on a cable reel stand or just roll it out
  2. KIAB
    KIAB Well-Known Member
    Prefer to roll it out, might need to secure as you go.
    wiggy likes this.
  3. wiggy
    Does the reel not just fall apart
  4. KIAB
    I leave wrapping on roll & unroll pipe as you walk feeding pipe into the trench with 50mtr rolls, might be harder with the 150mtr rolls,with the large rolls we lay it on ground drive 3 stakes around outside to keep it in place & pull it off,having some to help is useful.
    wiggy likes this.
  5. gas monkey
    gas monkey Well-Known Member
    As you roll out you cut the ties and each time only lets that bit off the coil but do not cut all or the wrong ties you will understand when you look at the coil
    KIAB and wiggy like this.
  6. wiggy
    Cheers KIAB, we stuck a pole through them and 2 of us walked them down without too much of an issue.
    KIAB likes this.
