3way valve put in the wrong way by plumber
Discussion in 'Plumbers' Talk' started by Din21, Nov 30, 2021.
  1. Din21
    Din21 New Member
    Can you let me know if there will be any damage done to the water cylinder if the 3 way valve is put in the wrong way round?
    They will be putting this back the right way round.
  2. quasar9
    quasar9 Screwfix Select
    What do you mean “wrong way round” ? . A 3 port valve has one input from boiler and two outputs, one to cylinder and other to the radiators. If swapped, it won’t do any harm other than heating your rads instead of the cylinder and vice versa. When calling for both heat and hot water, there will be no difference.
    Din21 likes this.
  3. nigel willson
    nigel willson Screwfix Select
    Nothing dangerous, however will not function correctly. Why do you think this has happened?
  4. Din21
    Din21 New Member
    The boilerman fitted it the wrong way, we only discovered it when we went to switch the hot water on and the radiators were getting hot
    also, the heating comes on upstairs and not downstairs and the water doesn't heat up properly
  5. Teki
    Teki Screwfix Select
    If there is only one valve, it seems you have more than just a swapped port issue. Perhaps you need to hire a more competent plumber?
  6. JOMEL
    JOMEL Active Member
    Former Plumber here.
    I fear for the future.
    Johnny M
  7. Din21
    Din21 New Member
    So do I
