50mm to 40mm waste pipe reducer
I have some grey plastic solvent waste pipe, its outside dimension is 51mm.
It disappears off into the kitchen behind some units and then goes outside…
I want to replace it with some 40mm push fit pipe. I plan to do it stages - the kitchen / outside section can wait a few months.
The push fit pipe has an outside dimension of 41mm.
How so I join the 2 bits together??
You’ll need a 50 to 40 compression fitting. Google should find you one.
Back
Top
