8.5kw shower cable
Discussion in 'Electricians' Talk' started by lvlouse, May 13, 2018.
  1. JP.
    JP. Screwfix Select
    Oh dear . lol, its all good fun..:)
    KIAB and Heat like this.
  2. Bazza-spark
    Bazza-spark Well-Known Member
    Can you deny that the original design was 10mm? No! So it should remain in 10mm.
    And I still would not put 6mm on a 40A breaker. You and @Risteard can do so if you like, but I wouldn't do it. Ok? My choice.
  3. Coloumb
    Coloumb Well-Known Member
    Oh dear oh dear oh dear. My oh my. One is very impressed with your level of back peddling but I'm afraid you are still wrong. You are referring to the OP which is "this post". "This post" is this situation. This situation being the op running 10mm through 2m of insulation and thence to 6mm for the last two m.
    If I brought a fully populated CCU which had a 40A circuit breaker and the situation is as described in this post then I would have no qualms using it"
    This post is this one...
    https://community.screwfix.com/threads/8-5kw-shower-cable.199423/
    Who, in their right mind, would think it to be any other one? This is what you said and this is what you meant. Don't try and wiggle out of it.
    So it would seem your totally cool with that? Running 10mm 2m trhough insulation? Even though it's a major breach of 7671?
    Obvs. you haven't been on the forum long so no one really knows what your level of experience might be, but to recommend something like that and NOT have any qualms, well I would say that's a pretty sloppy understanding of the situation AND 7671.
    You know what? I'm DIY. I don't do any sparking. Never have, never will. But it seems pretty damn clear to me that I already know a great deal more than you.
    So, for the third time, are you a spark?
  4. Risteard
    Risteard Well-Known Member
    Believe me it's obvious that you're not an Electrician. You are a know-all who knows * all.
  5. Coloumb
    It's times like this I really don't know what you except me to say?
  6. Bazza-spark
    Kettle and pot come to mind.
    Go suck up with your new mate Hollie who was the one Coloumb was addressing, not you.
    KIAB and Coloumb like this.
  7. Mike83
    Mike83 Well-Known Member
    A few weeks ago I thought sammi was DA.
    Now I'm sure Hollie is Lee.
  8. Hollie
    Hollie Member
    Only took you four days to come up with that reply even though you've been active on the forum. Just to clarify again as you are obviously a *....you are ignoring the fact the post says "in this post" you can read the quoted post that's says "in this post". You are choosing to highlight in red the bit that says "situation is as described" and ignoring the three words that follow that say "in this post". The whole sentence says "If I brought a fully populated CCU which had a 40A circuit breaker and the situation is as described in this post then I would have no qualms using it". Do you understand what as described in this post means?
    Described means To give an account of in speech or Writing
    This means
    Used for a person, object, idea, etc. to show which one is referred to
    A post on a forum is part of conversation in the form of posted messages.
    And yes it is clear you are DIY and also * as you cant grasp what "this" means.
    There is no way
    I'm back peddling as I'm correct and you are wrong . You are the one who has got their knickers in a twist over it all.
    If you actually read your own posts back you would see they are rather embarrassing . You can't comprehend what "this"means. *
  9. Hollie
    Hollie Member
    Just like Risteard was addressing Coloumb, not you. I notice you didn't come running to your other * rescue when a picture of his disgraceful work was plastered over the forum.
  10. Bazza-spark
    I see a ban looming.
    I also didn't see the photo you are referring too, probably because I don't have a *.
    KIAB likes this.
  11. Coloumb
    THIS is the best you can do? Pathetic.
  12. Coloumb
    Lee - just to recap.
    Your wrong about this post.
    You where wrong about the crimps.
    You where wrong about the docusa document/3m rule.
    You where wrong about the 3m rule reg in 7671.
    You where wrong about the loft insulation.
    When you left you said you where never coming back...
    1.jpg View attachment 24190
    looks like your wrong about that too.
  13. Bazza-spark
    Oh dear, I did try and warn him the Mods wouldn't be happy about his bad language. I got my wrist slapped for quoting him.
    Wash his mouth with carbolic soap!! :mad:
    Kind regards
    KIAB likes this.
  14. KIAB
    KIAB Well-Known Member
    :D
  15. Coloumb
  16. Hollie
    Hollie Member
    Not to you I haven't. You don't seem to be able to grasp the most simple of things so I can't be bothered with you ;)
    Risteard likes this.
  17. Coloumb
    You don't seem to be able to grasp that your LeeSparkyKent, who clearly said you weren't coming back. So your wrong about that and wrong about this post.
  18. Josh.91
    Josh.91 Member
    Few tired heads on here today haha
