8mm x 140mm Screws Into 3" by 2" Struggling
Discussion in 'Carpenters' Talk' started by Carl_m, Dec 10, 2018.
  1. DIY womble
    DIY womble Well-Known Member
    Kiab will know where to get extra long bits ,
  2. DIY womble
    That was quicker than I can type
    teabreak likes this.
  3. Jord86
    Jord86 Screwfix Select
    The rough answer is to buy a 4mm SDS drill bit and use that as the pilot if you really need to, even though they're not designed for that purpose, it will still do the job.
    KIAB and DIY womble like this.
  4. Astramax
    Astramax Super Member
    If the treated timber is damp spray the screws with WD40 then wind them in.
  5. sospan
    sospan Screwfix Select
    One of the cheapest places to get things like 4mm drill bit 100mm long is surprisingly Amazon - about £2.50
  6. KIAB
    KIAB Super Member
    DIY womble likes this.
  7. sospan
  8. KIAB
    KIAB Super Member
  9. Gringo28
    Gringo28 Active Member
    Don't think I've ever seen an 8 x 140 mm screw.
    The code 13977 shows a 6 x 140 mm screw.
    200nm is the maximum on a 1/4" hex driver. Though I think fein has a 210nm machine.
    I've seen 150nm machines struggle with a 6 x 140 into soft wood.
