9mm or 12.mm for MF ceiling?
Discussion in 'Builders' Talk' started by Mr Paul Bond, Jul 4, 2021.
  1. Mr Paul Bond
    Mr Paul Bond New Member
    I've installed the framework and in the past used 9mm as it is lighter and easier to handle.
    Do you think there is much acoustic merit to using 12.5mm? I'll be putting Knauf sound insulation between frame and old ceiling.
    Thoughts welcome :)
  2. Jord86
    Jord86 Screwfix Select
    Depends on the centres, but in all cases forget about 9mm on a ceiling. Use blue soundbloc plasterboard or opt for 15mm thick regular ones if you want it denser.
  3. Wayners
    Wayners Screwfix Select
    Hire a board lifter. £30 a day or £55 ish for a week as makes job easy and safer
  4. Peter Burrows
    Peter Burrows Member
    9mm snap too easier and are often harder to work with as bendy.
  5. Mr Paul Bond
    Thanks for advice, all. Much appreciated :)
    Board lifter sounds like a good call.
