acrylic matt paint for interior wood
Discussion in 'Painters' Talk' started by woodburner, Nov 25, 2008.
  1. woodburner
    woodburner New Member
    Hello,
    I have used Wickes's acrylic matt undercoat paint on ceiling beams. I presumed that Wickes would provide an acrylic matt overcoat but they don't. The effect is fine and pleasing so do I have to use an overcoat? I haven't been able to find an acrylic matt overcoat anywhere.
    Any suggestions would be much appreciated.
    Thanks,
    wb
  2. woodburner
    Is there such a thing as an acrylic matt overcoat or am I am asking a daft question?
    wb
  3. Burlington Bertie
    Burlington Bertie New Member
    If you're happy with the finish, why bother?
  4. polly222
    polly222 Member
    are you painting the beams black because i know you can get a matt black in oil based which you can get at crown or dulux centres.
    as for other colours im not sure i know you can get water based gloss but as i said im not sure about colours in matt. hope this helps polly
  5. woodburner
    Hi P and BB,
    The beams are to be white.
    If there are no technical reasons as to why I shouldn't stick with it I will.
    Cheers,
    wb
  6. Brushmanpaul
    Brushmanpaul New Member
    Wickes paint is rubbish its a bit like coloured water. I didn't know they did clothing as well! Ha ha!
    Seriously - if you leave it in undercoat the substrate wont be sealed and the moisture from you bathroom will be absorbed into the undercoat. You really ought to put a finish coat. if you want to keep it matt how about Matt Varnish (Acrylic). Dulux Diamond Matt is excellent.
