Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
How would you fit a plug top to an oven? A complete plug is possible though.I would have thought if it were suitable for a 13A plug top it would be fitted with one.
Just bought an electric oven but came without a plug so I am adding a plug on, it’s a 13amp fuse in the plug, is it ok to use that fuse or do I need to put in a smaller one. The oven specifications say it is 13amp.
I quoted plug top just for you George.How would you fit a plug top to an oven? A complete plug is possible though.
If the oven specifications say 13 amp why on earth do you think a smaller fuse would be suitable or even last?
I said the smaller fuse as when I have previously added a plug onto a kitchen extractor hood I was told to put in a smaller fuse. It's fine now anyway the oven is in.How would you fit a plug top to an oven? A complete plug is possible though.
That is why fuses are not used in plugs in other countries.
How jingoistic!
The United Kingdom's Type G plug, also known as the BS 1363 plug, is used in over 50 countries worldwide. These countries often have close historical ties to the British Empire, such as:
Ireland, Hong Kong, Malaysia, Singapore, Cyprus, Malta, Gibraltar, Jordan, and Saudi Arabia.
And, to add, in places such as India and South Africa which use the older round pin that was common in the UK, there are now fused variants available. They also make shuttered sockets to improve safety.
How jingoistic!
I am aware of that. Read my post again. I did not say "all" other countries.
I always believed that a cooker that comes with just the wire and no plug has to be hard wired?
Most electric ovens are comfortably under 13 amps and can be plugged into a wall-socket but often don't come with a plug because they will most likely be wired into a cooker isolator.
Electric hobs on the other hand can be rated at up to 2k and usually need to be wired to an isolator.
At some point they stopped supplying cables with all-in-one oven and hob combo's to stop people putting a 3-pin plug on them - not sure if that is still the case though.
Some ovens are under 13A, but if the manufacturer does not fit a 13A plug before sale, they should be hard-wired.Most electric ovens are comfortably under 13 amps and can be plugged into a wall-socket but often don't come with a plug because they will most likely be wired into a cooker isolator. . .
Electric hobs can be rated up to 7kW.. . . Electric hobs on the other hand can be rated at up to 2k and usually need to be wired to an isolator. . .
How would the oven know if it's on a plug or wired in? I thought it was just about the number of watts/amps consumed by the appliance?
Self-cleaning and rapid-heat models can consume more power and push the consumption above 3k and therefore need to be wired in.
