ADE Optima Compact Gen4 by Honeywell - double beep?
Discussion in 'Electricians' Talk' started by jimwillsher, Oct 31, 2021.
  1. jimwillsher
    jimwillsher Member
    Hi, am looking for some help. I have an ADE Gen4 alarm (Accenta, Optima, Honeywell). I have two zones, zone one is a door sensor and zone two is a PIR. It’s covering just a small workshop. I only have LED panel, not LCD.
    Last week the alarm triggered, for no apparent reason.
    Since then, when setting the alarm via the keypad, instead of beep beep beep I get beep beepbeep beepbeep beepbeep. In other words, one beep followed by a succession of double beeps. It never used to do this.
    When it’s doing this, I open the exit door and it changes tone, as expected, to the rapid beeps, and when I shut the door it does the expected beep beep beep for ten seconds and then sets.
    I can find no information, anywhere, on what the beepbeep beepbeep might signify. Can anyone suggest? There are no zone lights illuminated when setting, just the green LED beside the open padlock and the red LED on the power light.
    Many thanks.
