Adhesive Trowel for 30 x 30 tiles
Discussion in 'Tilers' Talk' started by Iron_Mike, Mar 23, 2018.
  1. Iron_Mike
    Iron_Mike Active Member
    Hi
    I installed some 60 x 60 tiles and am now moving onto installing some smaller tiles (30x30).
    What adhesive trowel do you recommend I use to install these smaller tiles ?
    The tiles are going on the floor.
    Cheers
    IM
  2. KIAB
    KIAB Well-Known Member
    Larger the tile larger the notch.:)
    10mm notch, square or U.
    Wall tiles I presume, floor tiles you could go 12mm notch.
    6mm notch = 6-8inch tile
    8mm notch = 8-10inch tile
    10mm notch = 10 -12inch tile
    12mm notch would be used for any tile over 12 inches.
    Iron_Mike likes this.
  3. Iron_Mike
    Thanks KIAB
  4. CGN
    CGN Well-Known Member
    As Kiab says.
    Other things to consider are the general 'flatness' of the surface you're tiling. If you have a poor surface, then up the notch size and check you're getting full coverage on the back the tile. Remember to back butter as well.
