Adjusting veneer doors
Discussion in 'Carpenters' Talk' started by Smudge01, Jan 13, 2021.
  1. Smudge01
    Smudge01 New Member
    I've been asked to fit self closers on these doors, however, they don't actually close properly. I can't take anything off them as they are veneer finish.
    They don't appear to have dropped on the hinge, and there's nothing obvious that I can see that would cause this problem, so I'm not sure why they don't close any more.
    Has anyone come across this before, and can you offer any advice please?
    Than you in advance.
  2. I-Man
    I-Man Active Member
    you need to identify exactly where the doors are not fitting right. Could be binding on the hinge edge, or top frame etc..
    Use something like a filling knife or even a credit type card and feel all around the door to see where it's getting stuck
    Smudge01 likes this.
  3. Smudge01
    Smudge01 New Member
    Thanks for your reply. I should have explained in more detail.
    Where the doors meet, they are fine from the top of the doors to the middle, but then from the middle of the door (where they meet) down to the bottom, one slightly overlaps the other by about 5mm.
  4. I-Man
    I-Man Active Member
    So perhaps the overlapping door needs the bottom hinge moved back slightly...unless of course it's the door that's bowed/bent (unlikely)
  5. Smudge01
    Smudge01 New Member
    Sorry my bad explanation again. The door aren't bowed, they won't close because of the overlap. The gap at the top half of the doors are fine (if they could close), it's the bottom half that's preventing them from closing.
  6. I-Man
    I-Man Active Member
    maybe you can share a few more pics showing the issue in more detail?
  7. Smudge01
    Smudge01 New Member
    Fair point.
  8. Jord86
    Jord86 Screwfix Select
    They are veneer faced but surely to God must be able to be planed, there should be a solid timber lipping around the edges, whip the master door off and look at the top and bottom, if it's obvious then take the 5mm off, the edge will obviously need refinishing.
  9. Smudge01
    Smudge01 New Member
    Thank you.
    How would you re-finish the veneer?
    Won't the veneer chip, in the same way as if you were to run a planer along the edge of a laminated worktop?
  10. Dan Parkinson
    Dan Parkinson Active Member
    The faces are veneered, the edges are solid. Either trim the door with a sharp plane, a planer or a router with a straight edge.
