Hi,
I am just about to start back into my garden project, composite decking is being delivered in the next few days and I would like to get the frame built. I was hoping for a bit of advice on the best way to do it.
The plan is to raise the decking to be at a level just under the patio doors, hiding the existing patio and making it all one level. I am going to run the boards along the 6.2m length to give the feel of it extending the room when the patio doors are open.
The person who sold me the decking(and a few others who I got quotes from) all said that they would build on top of the existing pato without lifitng the flags, one of them also said that they wouldn't attach a ledger board to the side of the house because of the difference between the render and the brick.
I was worried about the decking being above the dpc but they all said that this wouldn't be a problem as long as I left a small gap between the 2 walls and the decking boards.
I've been doing a bit of research but I don't know what the best approach would be. I think I have 2 options:
attach the ledger board to the brick with extra spacers to come out in line with the render and run joists across, then concrete posts into the garden area and frame it there.
Or make 2 beams, 1m from the wall and 1m in from the garden running the 6.2m, then sit the joists on these.
I have a few other questions:
what size would you use for the joists?
The joists have to be at 300mm centres for the decking that I've bought and they recommended that I use 6x1 for joists but others said 4x2.
If I was to use 4x2 joists across suport this with a 4x4 post in the centre of each joist would that be ok?
If I was to put posts directly onto the flags and just put down some dpm would that be ok or should I use a post shoe and drill it into the flag? Someone recommended I put a breeze block down on top of the flag and set the post on top of that.
Most videos I have watch have the joists attached to a ledger board with joist hangers, though I have seen some that have them actually sitting on top of the ledger board instead, which way is best?
Many thanks
*edit: image links wouldn't work
https://imgur.com/a/utIvIpV
Many thanks
