Advice needed
Discussion in 'Screwfix' started by Sandra1/, Mar 28, 2023.
  1. Sandra1/
    Sandra1/ New Member
    Hi, can anyone recommend the best approach to fix this issue?
    Thanks in advance!
  2. robertpstubbs
    robertpstubbs Screwfix Select
    It looks horrible, and I can’t tell whether there is any structural failure. What particular issues do you want to address? What is your objective?
  3. Sandra1/
    Sandra1/ New Member
    Hi Robert,
    I just want to fix the missing brick / idk fill with something but I do not want to make any mistake as I don't know what should be applied here..do you think this is a structural issue?
  4. robertpstubbs
    If you have the right tools you can remove a damaged brick and replace it. The tools can be hand ie hammers and chisels, or power eg SDS.
    In an ideal world you find a matching brick but TBH anything would do here.
    I think you should find somebody local who can check how serious the overall deterioration is.
  5. Sandra1/
    Sandra1/ New Member
    Thank you Robert, I thought I could fix this myself...oh joy
  6. robertpstubbs
    If you just want to fill the space you could glue some bits of brick in place with mortar, or maybe even just fill the whole gap with mortar, but there is long-term deterioration which will need addressing at some time.
  7. Alan22
    Alan22 Super Member
    Is the other side neater and sound? I'm guessing this side was not seen or something and you are trying to make it cosmetically more presentable?
    A stone repair mortar with a colour through it would build the brick back up and patch a few others, but you would still have all the snottery pointing.
