Advice on attaching electrical boxes
Discussion in 'Other Trades Talk' started by Matrad, Mar 11, 2018.
  1. Matrad
    Matrad New Member
    Hi all
    Any advice on how to effectively attach ectrical boxes to brick & Block walls that have been very badly chased i.e. A very uneven back with up to 3cm to fill in some parts to get them to finish slightly proud of the wall ready for plastering?
  2. chippie244
    chippie244 Well-Known Member
    Expanding foam?
    WillyEckerslike and KIAB like this.
  3. dobbie
    dobbie Well-Known Member
    You will need to flatten the brick or block using a comb chisel,chisel or and bolster,whichever is your choice.
    When you have the bricks/blocks flat fit deeper boxes or fit extension collars to the boxes to bring out to plaster finish.
  4. dobbie
    Where is your horse stabled.
  5. Matrad
    Matrad New Member
    Is there a specific type of foam for this, in addition would this be a sound enough fix.
  6. chippie244
    I'll await other opinions.
  7. dobbie
    That is a cowboy bodge job.Do it properly.
  8. HarDeBloodyHarHar
    HarDeBloodyHarHar Active Member
    Chuck a wodge of sand/cement mix in there, scrape it to required depth, Bob's ur uncle etc.
  9. KIAB
    KIAB Well-Known Member
  10. dobbie
    Certain foams used to damage the pvc on cables,read regulation 522.5.3.
    Kiab I have, unlike you, worked in the building and construction industry on sites,both industrial, commercial and domestic over the years.
    Every thing I know is through actual experience and not browsing diy forums.
    From what I gather you once maybe worked in a builders merchants.
    I will not be the only one on here who laughs at the porkies you come out with,maybe some of the stories are true you heard when behind the counter.
  11. KIAB
    I've worked both side of the counter, mainly domestic nearly 40 years, make it 35 years, if I allow for accidents,etc.
  12. Sparkielev
    Sparkielev Well-Known Member
    I have used foam when I have encountered hollow brick walls were you can't get a fixing or fast dry cement, in this case tho just level off brick fit a deeper box
  13. DIYDave.
    DIYDave. Well-Known Member
    My favourite ..... gotta be bonding plaster;
    Almost no depth limitation
    Cheap
    Sets even quicker if outta date
    Dampen brick or PVA 5-1 water
    Chuck in bonding
    Tap in back box to required level
    Drill and plug through bonding into brick
    Semi tighten screws, fully tighten once bonding set
    I’m only diy me but I’ve used this method few times and it’s a lovely job :)
    DIY womble likes this.
  14. chippie244
    So pretty much like using expanding foam. :)
  15. metrokitchens
    metrokitchens Well-Known Member
    Bonding plaster all the way. Fill the hole and set the back box in. Push in a couple of red plugs and screw when dry.
    Jobs a good un. Tea and biscuits time.
  16. DIYDave.
    Thing is with me as diy, whenever I’ve bought a can of foam, I only need a squirt of it, never the full can
    Have a can of the Everbuild foam cleaner and it’s really excellent stuff. Cleans the spray tube in seconds and cleans the nozzle on the can
    Can goes back into garage for some months, next time you need to use it, can never works, even though I’ve cleaned it out so waste 80% of the can
    Not worth me buying gun and gun grade foam, just don’t use enough
    So for me, I decant a sack of bonding into two 10ltr paint buckets and it lasts me for an age
    As mentioned, when out of date, it sets quicker which can be handy and if using for a small repair, is fine as you may only have 5-10 mins workable time
    So no, nothing like foam really chips :)
  17. DIYDave.
    Cheers metro, my thoughts exactly :)
  18. chippie244
    I meant the technique, I use lots of foam but never use bonding so don't have any of that around.
  19. Matrad
    Matrad New Member
    Thanks for your response
  20. Matrad
    Matrad New Member
    Thanks for your response.
    Do I need to make the bonding mix thicker than normal & will the box need to by held in place while it goes off?
