Advice on getting a Loud internal Sound device bomb
Discussion in 'Electricians' Talk' started by bond007, Mar 26, 2019.
  1. bond007
    bond007 Well-Known Member
    Guys
    I have a veritas R8 Alarm panel and wanting to put an internal Sound device bomb.
    Any advice which is a good one and Loud.
    Also advice on the wiring please too.
    Thanks
  2. gas monkey
    gas monkey Well-Known Member
    big dog workss
    bond007 likes this.
  3. Vixere
    Vixere Active Member
    If I break in to your house and that sound bomb makes my ears hurt, I'll sue you.
  4. bond007
    That's if you get out in one piece :)
  5. Vixere
    Ah, but your ears will be hurting too. Unless you have earplugs on standby?
  6. Pollowick
    Pollowick Screwfix Select
    I use them, normally on Texecom Premier Elite panels.
    There are several options, 2 piezo with strobe, 4 piezo or go to the Master Blaster. Do you have a sound level in mind and do you need the strobe?
    I can point you at the right ones iof you say what you need.
  7. bond007
    I just need one for internal use, as when alarm goes off we cant really tell if its the neighbors or ours.
    I have a call dialler fitted which has its own internal sound, but want something in the hall way which will ensure we realise when our alarm goes off.
    Thanks
  8. Pollowick
    So, do you need an extremely loud sound bomb, or just a speaker?
  9. bond007
    Depends on the price difference really....something that will do the job to indicate the house alarm is going off
  10. Pollowick
  11. bond007
    I have the Veritas R8 panel, i am sure it has an internal speaker but not very loud
  12. bond007
  13. Pollowick
    The panel has an internal speaker, but also a pair of speaker outputs which you will use to drive a speaker.
    However, in your case, just go for the SOSB1L which is a dual piezo and is LOUD. Wired between 12v and sounder output.
    bond007 likes this.
  14. bond007
    Thanks for ll your help.....any advice on how to wire it please?.....
  15. Pollowick
    Do you have the Veritas installation manual?
    What ever you do, you need to put the alarm in Engineer mode before you start, be aware of the 230v input- and ideally power it off completely.
    Wiring is easy, just do a search online forr the maunal and it is all covered in that.
  16. bond007
    https://www.spyalarms.co.uk/wp-content/uploads/2010/10/Veritas_R8_manuals-1-.pdf
    this is the manual
  17. Pollowick
    That is the one ... I have it on my phone.
    Page 7 shows the board and teh connections, Page 12 tell you how to wire it. Page 15 covers how to access the panel.
    Everything you need to know is there.
  18. bond007
    red from bomb to +12v and black from bomb to bell ?
  19. Pollowick
    That sounds about right.
    You can test it out, with ear plugs, by putting the soundbomb across a battery.
  20. bond007
    Also what if i want to put the sound bomb further away from the panel - more than the 15cm wire provided
    Will i have to open the new sound bomb up and put a new cable or join it with a connector block
    thanks
