Hi Guys I have just removed some old wall paper in my house I'm renovating i was just wondering what was the best way to things. The wall paper came off relatively well and walls arnt bad just need some filling hear and there. Do i need to clean the walls with sugar soap if im going to fill and then the whole wall down? or do i fill and sand then clean? Any advice would be appreciated i want to do the job once and properly
A good wash with sugar soap before you do any more. It may not look like it but there will be a lot of dried wallpaper paste residue left on the wall and it's a nightmare when that reacts with paint. When you've washed a section and it's still wet, slide your fingers over the surface and you'll be able to tell if there's still any paste residue due to a 'slimy' feel, then fill and sand as normal. Good luck.
Sand walls. Use zinsser gardz to seal as will neutralise the paste. Fill and make good then sand. Prime filler bits with gardz. Paint. I buy off net. Ebay is good and it goes a long way.
