Advice on treating oak doors please
Discussion in 'Painters' Talk' started by David Cecil, Jun 6, 2021.
Tags:
  1. David Cecil
    David Cecil New Member
    We have had 2 oak doors fitted in our new utility. All the other doors in our house are actually pine and are quite yellow/golden.
    Could anyone please advise the best oil to treat the oak doors with that will look good but also make them look as golden as possible so they match the pine doors as much as possible?
    I know the oak and pine doors will never be a perfect match with each other but would like something that makes them look compatible with each other.
    All help greatfully appreciated
    Thank you
  2. David Cecil
    Should have mentioned, the oak doors are engineered oak not solid oak
  3. Astramax
    Astramax Super Member
    Take a look at the Osmo range of finishes for this type of required finish.
