Advice on unblocking external drain
Discussion in 'Plumbers' Talk' started by Adrian Hite, Nov 19, 2023.
  1. Adrian Hite
    Adrian Hite New Member
    Hello all.
    My external drain, underneath a downpipe, is blocked with rainwater. I believe the cause is cement washed down from when my patio was laid a year ago.
    I have tried to scrape it away and dissolve it but nothing seems to work.
    I have noticed what looks like a turntable plug, almost like a potential overflow, that could be openable, and this might release the water down a side drain. But I'm not sure if this is feasible and if so what tool could be used. Any advice would be greatly appreciated. I'm clearly a non plumber and scrambling around for direction. Photos attached. The potentially turntable plug device is seen through the grate.
    Thanks in advance...
    Adrian
  2. qwas123
    qwas123 Screwfix Select
    OP,
    Typically, the down pipe discharges into a trapped gulley.
    Can you stand back and photo a much larger context showing the whole elevation?
    Is there a manhole cover nearby?
    Why not lift & remove the grate, & reach down with a gloved hand and a small container and empty the water and any sludge - & then photo the dry'ish gulley?
    The waste tissues trapped in the grate look like toilet paper - where did they come from?
  3. stevie22
    stevie22 Screwfix Select
    Does your "turntable" have a hollow thread sticking out of the middle? Picture's not clear but it sounds like a pipe stopper which would be a temporary job.
  4. Adrian Hite
    Hi both, here is a better photo and yes it is actually a plug. It says remove for rodding. Is there a tool available to do this. It's quite tricky to get at so a specific tool would be ideal.
    Adrian
  5. stevie22
    That should just be a friction fit with a rubber seal so it should just pop out with a flat blade screwdriver or a small flat prybar.
  6. Adrian Hite
    Thank you very much. I'll give that a go. I appreciate it.
    Adrian
  7. qwas123
    OP,
    You have a trap with a rodding point.
    Leave the rodding point plug alone until the trap is free of debris and sludge.
    Thoroughly clean out the trap - debris can still be seen.
    The plug looks like its an expanding plug with a screw head for adjusting expansion - the two ears are probably for twisting it out of any locked-in position, & breaking any seal.
    After clearing the debris try a hose pipe down the trap - if no luck then remove the plug and you will have the choice of DIY rodding or jet hosing.
